QA1 Shocks
QA1 Shocks
I am about to replace the stock suspension on my 95 z28 with double adjustable QA1 shocks. I am purchasing both front and rear shocks along with front springs, I am looking at 300lb springs for the front. Is there anything else that I will need to purchase to install these shocks onto my car?
Do yourself a favor and get the Stranges instead of the QA1's. When I was stuck between QA1's and Strange I talked to a few sponsors on here that sell both and they all said the Stranges are better quality and not to mention are a tad cheaper. I too run a 300# front spring. Get yourself the torrington bearings and spanner wrench so ride height adjustments upfront are easier.
Besides that your good to go. Install is a piece of cake, if you've never done a shock/spring swap check out ls1howto.com they have a good writeup.
