who sells lt1 to ls1 motor mount conversions?
If I am not mistaken, the LT mounts are the same as Gen 1 engines. To convert to LSx engines you would need the adapter plate. I got mine off of fleabay for $19. I have seen them as high as $199 in catalogs. Basically the adapters let you bolt the engine to regular Gen 1 engine standoffs. Street and Performance sells them too. My car is a 65 Impala that had a 283, I originally wanted to put a LT1 into it. The engine mounts from the Gen 1 bolted right to a LT1. I then changed my mind and went to a LSx engine. Then I needed the adapter plates on fleabay. Good luck.
