revert grind, what I need to check ?
just bought the car, 97 z28 m6, new gm clutch 500 miles break in, some time I put on revert it grind, I take it off and put in revert again, it go in without grind. every other gear shift fine. some time it hard get into first while moving, can be clutch need to be adjust ? is this tranmission problem or clutch problem ? what I need to check first ? thanks !
