Summit Stars. Has anyone bought/fitted them?
Old 07-06-2010, 11:26 PM
OHH RLY?'s Avatar
Default Summit Stars. Has anyone bought/fitted them?
If so, what size/offset is best? Grinding of calipers an issue? Looking to get a set for my Z28. Any help is greatly appreciated!
Old 07-07-2010, 07:21 AM
kierstyn's Avatar
8s in the rear with 5.5 bs and 4s or whatever it is they offer with the 1.75 bs for the front. As for grinding its a test fit thing some fit some require grinding. For the fronts I think you can run a 5/16 spacer with no grinding but will require longer studs. I have welds so mine may be a little different but thats how it went on mine. Also try a search on here theres a few threads on these that may help you out.
Old 07-09-2010, 11:34 AM
1999Black_Z28's Avatar
I have the summit stars (15x8x5.5) on the rear of my car. It required very minimal grinding. I am running greg welds in the front with no grinding.
Old 07-09-2010, 04:45 PM
zracer323's Avatar
I run the exact same setup. A little grinding on the rears, none on the front.
