Anyone work at GM dealership or have drawings?
Old 07-07-2010, 03:50 PM
Shackleford's Avatar
Default Anyone work at GM dealership or have drawings?
I can lift up the left side, but it falls back down. Nothing appears to be broken. My Dad said I have to put some adhesive or something back up the hole where the support is.
I want to see what the factory schematics have up in the hole.
Old 07-07-2010, 04:05 PM
Ravenous T\A's Avatar
Rear Compartment Lift Window Panel Replacement
Removal Procedure
Raise and support the liftgate window panel.
Remove the headliner trim finishing panel. Refer to Headlining Trim Panel Replacement in Roof.
Remove the liftgate strut ends (2) from the liftgate mounts (1) and allow the struts to rest in the rear compartment.
Remove the harness conduit (2) from the vehicle body (3).
Disconnect the liftgate electrical connectors (4) from the body harness.
Remove the nuts (2) from the liftgate studs (1).
Important: When replacing the liftgate panel, remove the hinges and the spoiler and transfer to the new assembly.
Remove the gaskets from the hinges and remove the liftgate from the vehicle.
Installation Procedure
Install the gaskets to the hinges.
Align the studs on the hinges with the holes and install the liftgate to the vehicle. Support the front of the liftgate until the struts are reattached.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the nuts.
Tighten
Tighten the nuts to 25 N·m (18 lb ft).
Connect the liftgate electrical connectors (4) to the body harness.
Reinstall the harness conduit by performing the following steps:
5.1. Route the harness.
5.2. Apply a soap solution to the grommet.
5.3. Seat the conduit at the window panel and roof frame.
Install the liftgate strut ends (2) to the liftgate mounts (1).
Important: A snap should be heard when the strut ends are fully seated. Verify that the strut ends are securely installed by tugging firmly on the strut ends.
Install the headliner trim finishing panel. Refer to Headlining Trim Panel Replacement in Roof.
Old 07-07-2010, 04:07 PM
So, I need to replace the gasket up in the hole. I bet that damn thing at the dealership is $30.
Old 07-07-2010, 04:20 PM
Old 07-07-2010, 04:21 PM
straight from the service manny, sorry this is all it showed for that replacment
Old 07-07-2010, 04:25 PM
Hmm. Thanks for the info, man.
Old 07-24-2010, 06:20 PM
Faze's Avatar
Are you just refering to the trim falling?
Quick Reply: Anyone work at GM dealership or have drawings?
