cam/Double roller timing set?
Will these 2 work together on a 388 stroker (scat 6 inch h-beam rods) with electric water pump and newer style opti spark? or do I need a small base comp 306? I already have the regular base cam and the timing set thats listed and motor guy said it might not clear rods. I am building this motor with all new parts so I can get the later optispark, etc..
Cam- http://www.jegs.com/i/Comp%20Cams/24...0002/-1?CT=999
Timing Set- http://www.summitracing.com/parts/CL...9&autoview=sku
or do I need
the cloyes 9-3145 and/or a small base 306 cam?
Thanks guys
or do I need
Thanks guys
