Will my CTS-V t56 fit on my ls1 with ls1 Pilot bearing?
Old 07-09-2010, 02:34 PM
Dltreezan's Avatar
Default Will my CTS-V t56 fit on my ls1 with ls1 Pilot bearing?
Ok guys I have an ls1 in my rx-7 (FC) and have everything hooked up and ready to go. The shifter was a pain in the *** but I got it to work. I also had a driveshaft made by a shop with the triangle flange fitting and all.
I am also using the CTS-v clutch, pressure plate and flywheel.
My only issue is do I have to put an ls6 pilot bushing instead of the ls1 pilot bearing I put in there. Everything seemed to mate up just fine and I am about ready to put the car on the ground and take it for a spin. Your thoughts would be appreciated.
Old 07-09-2010, 02:58 PM
Dltreezan's Avatar
I might have found my own answer. Dammit. Looks like I am going to have to pull that ls1 pilot bearing out and put the big one in there since the tranny is from a CTS-v. Any independent confirmation would be great. Thanks folks-
Derek
https://ls1tech.com/forums/manual-tr...-vs-small.html
Old 07-09-2010, 03:44 PM
85MikeTPI's Avatar
Yes, the CTS-v T56 input shaft is 1/2" shorter than the Fbody T56.
Quick Reply: Will my CTS-V t56 fit on my ls1 with ls1 Pilot bearing?
