which coil packs work with 99 LS1 harness?
Old 07-10-2010, 01:18 AM
jeffro_93's Avatar
Default which coil packs work with 99 LS1 harness?
I was wondering if the truck coil packs plug right into a 99 Camaro harness? If so, what year packs should I be looking for?
thanks in advance.
Old 07-10-2010, 01:27 AM
Paint_It_Black's Avatar
thanks in advance.
The truck coils swap in. The D585's even add a little performance in some cases, but you have to go into the computer and change the dwell time.
Old 07-10-2010, 01:29 AM
jeffro_93's Avatar
Thanks!
Old 07-10-2010, 01:38 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Moved to External from Internal.
Old 07-10-2010, 01:42 AM
jeffro_93's Avatar
Dang it, that's my fault again, sorry
Old 07-10-2010, 06:26 AM
That's MISTER MODERATOR
Paul Bell's Avatar
It's not as simple as that.
You'll need to change the coil harness and the coil mounting plate to match whatever coils you choose to use.
Much more here: https://ls1tech.com/forums/generatio...p-18-6-tq.html
