Torque specifications for spec super twin st trim
Old 07-10-2010, 10:08 AM
dsmgod24's Avatar
Default Torque specifications for spec super twin st trim
I need to know the torque specs for the bolts on my spec super twin. If anyone knows, please let me know so I can put my car back together. Thanks..
Old 07-10-2010, 01:04 PM
dsmgod24's Avatar
Does anyone know the torque specs for the flywheel bolts?
Also what are the torque specs for the Pressure plate??
I need to know today so i can put the clutch in.
Old 07-10-2010, 01:40 PM
dsmgod24's Avatar
Ok, all data says 75ft lbs and pressure plate is 55ft lbs. I was thinking 80ft lbs for flywheel and 60ft lbs for pressure plate. Can someone verify if this will be ok?
Old 07-10-2010, 08:40 PM
dsmgod24's Avatar
I know there are guys running this clutch.... What are the torque specs for the pressure plate?
Quick Reply: Torque specifications for spec super twin st trim
