can anyone identify these springs?
I just picked up a set of dual springs from a forum member. we are both unsure what they are, they came on a set of tfs245's. i am trying to identify them so i can order a set of retainers. any help would be appreciated. here are some measurements i took. sorry i just used a cheap caliper so they may be off a little.
inside spring
.770 id
.900 od
2.430 height (uncompressed)
outside spring
.875 id
1.270 od
2.120 height (uncompressed)
inside spring
.770 id
.900 od
outside spring
.875 id
1.270 od
well im an idiot, the id of the inner spring is 0.670. I guess i cant even read the dial on a simple caliper.
and yea. i was confused when the id of the outer spring measured smaller than the od of the inner. But if you think about it, i guess its just the way they fit together. its a tight fit, but these are springs and not two pieces of pipe. there is some give.
