6 ses codes...lil help please
Old 07-12-2010, 08:54 PM
Greenfire's Avatar
Default 6 ses codes...lil help please
I have 6 codes, the car has no emissions on it, it's a built 383.
I know for a fact the Crankshaft Position sensor is plugged in, still throwing the code P0336 Crankshaft Position Sensor A Crk Rng Perform
P1133
02S 1/1 Transit time ratio
P1441
EVAP system flow during non-purge
P0123
Throttle/Pedal Position sensor A Crk high inmput
P0135
02S Heater Crk malfunction 1/1
P0335
Crankshaft Position sensor A circut malfuction
Any help would be greatly appriciated.
Old 07-12-2010, 09:51 PM
SPEED#1's Avatar
probably a bad o2 sensor
tps is not set accuately
crank sensor code..are you sure you installed the reluctor wheels behind the timing cover for the sensor? If you did the sensor can be bad or will need to be shimmed
Old 07-13-2010, 06:22 AM
Greenfire's Avatar
I just replaced the passenger O2 since it said it was bad.
Do you have any insight on how we can check the reluctor wheels to make sure they are correctly installed? I had the motor built by someone else and I've had a few issues with it since. We did replace the crank sensor itself already.
Quick Reply: 6 ses codes...lil help please
