flywheel spacing?
Old 07-16-2010, 08:19 AM
martiniracing's Avatar
Default flywheel spacing?
i'm running an l33 with a t56. how do i know when i need a spacer between the crank and the flywheel?
Old 07-16-2010, 11:04 AM
garys 68's Avatar
You dont need one. The spacers are only forautomatics for the dished vs flat flexplate. An Ls1 flywheel/clutch will bolt up fine.
Old 07-16-2010, 11:13 AM
gofastwclass's Avatar
IF you have a T-56 from a Gen III / IV car. If it's a T-56 from an LT (pre 1998) car the spacing will be the Gen I / II offset. This requires a different flywheel and throwout bearing, the spacer is only for auto's.
Old 07-16-2010, 11:16 AM
so i won't need to space it? i am using 3gen t56 from an 02 camaro
