A-body firewall flexes with S&P master cylinder mount
Old 07-16-2010, 09:53 PM
pushrod36's Avatar
Default A-body firewall flexes with S&P master cylinder mount
I know a lot of people copy the S&P clutch master cylinder mount, and I did, too. When I push the clutch pedal in the firewall flexes a good bit. Has anyone else had this problem? What did you do to fix it?
Old 07-16-2010, 10:03 PM
txredxj's Avatar
. have seen people do a brake cylinder stopper but not sure how it will work with a clutch master. a couple plates that sandwich on the inside and outside of the fire wall would help to get a bigger load area also
Old 07-17-2010, 07:22 AM
Pop N Wood's Avatar
If the clutch works OK then why is it a problem?
Old 07-17-2010, 10:10 AM
bczee's Avatar
I made mine out of 1/4" steel and I have not noticed any. But if I was going to build another one, I would use a thicker maybe 5/16" next time.
Quick Reply: A-body firewall flexes with S&P master cylinder mount
