Those with iron blocks...swap information
Did you just put the passenger side ground from the battery on the motor mounts or what? My block has no boss or threads behind that. Just a small threaded hole similar to the ground on the driver side. Either would work, just curious if there is a reason why you did what YOU did.
Anything else kind of screwy when bolting up accessories or anything else?
I did away with my A/C so I put my main ground cable to one of the bosses that normally went to the A/C bracket. I took a scuff pad and sanded it down real good too that way it made good contact.
Accessories on my particular LQ4 block, I had to drill and tap one of the bosses to the alternator bracket. There are 3 bolts on a stock LS1 but you will only be able to use 2 on a iron block because the 3rd boss isn't there and the top one is there but not drilled and tapped. Not a big deal just use lots of cutting oil and make sure you drill it straight and tap it straight as well.
