What should i do
Old 07-18-2010, 10:05 PM
lethal bird's Avatar
Default What should i do
I going to soon be gathering parts for my H/C swap tell me if i missed anything.
Ai 200cc heads
ai 230/238 cam
Ai ported intake
Injectors
new opti
lifters
spec 3+ clutch
spec flywheel
moser 12 bolt, true trac 33 spline, 4.10
nitrous outlet 125 plate kit
Old 07-18-2010, 10:09 PM
RamAir95TA's Avatar
Ai 200cc heads
ai 230/238 cam
Ai ported intake
Injectors
new opti
lifters
spec 3+ clutch
spec flywheel
Pushrods, rockers, tune, timing chain/sprockets, to name the obvious things off the top of my head.
Old 07-18-2010, 10:12 PM
Yea i knew those. I was just going to get the Ai complete cam kit
Old 07-18-2010, 11:40 PM
StealthFormula's Avatar
Gaskets.
If you are doing the work yourself I would get some assembly lube, thread sealer, RTV, thread chaser kit, oil and filter for an oil change after 100 miles, stuff like that...
Old 07-19-2010, 08:06 PM
Wicked94Z's Avatar
ditch that crappy truetrac
Old 07-19-2010, 08:27 PM
hitmanws6's Avatar
Bigger TB
Old 07-19-2010, 10:28 PM
Originally Posted by hitmanws6
Bigger TB
already got an as&m 58mm monoblade
Old 07-20-2010, 12:42 AM
RamAir95TA's Avatar
Never heard of one of those...
Old 07-20-2010, 01:12 PM
94Z28rag's Avatar
That would be correct, sir!
Old 07-20-2010, 02:15 PM
excuse me my bad i was in a hurry i didnt mean to put 58mm.
Old 07-20-2010, 02:26 PM
jaycenk's Avatar
You will need to set up you tps sensor after you get it running so read up on that. You will also need a swear jar and lots of quarters so you can start paying your self for future mods lol.
Old 07-20-2010, 02:27 PM
RamAir95TA's Avatar
So you have a monoblade? How much did that run you?
Old 07-20-2010, 02:43 PM
$400 I bought it used from a friend of mine. Or is it going to be to much for what i will have. Im still new to all this and im just kinda learning as i go. The guy i bought it from said he only ran it for a little over 3 years and said that i would be fine.
Quick Reply: What should i do
