will 315's fit on the rear of my 00 SS??????
Re: will 315's fit on the rear of my 00 SS??????
If you use an 11" wheel with a 50mm (2") offset. They may still rub in a spot or 2, especially when cornering. Alot of folks bang in the areas where it rubs, to keep it from happening.
It isn't recommended to put 315's on a stock rim. Go to www.tirerack.com and look up the tire you plan to get and look at their recommended rim size. I'll bet it says to use an 11" rim. You also need the wheel with a 50mm (2") offset so that they will fit.
