Who has the QUICKEST STOCK SHORTBLOCK N/A??????
I went through the "fastest" list and saw a few burners in the 10's. Some don't list the displacement though, so I have to wonder. Also, a few of them are swapped into other generation f-bods, but the weights aren't TOO far off from gen to gen. This is what I have so far:
8. Bunny Mabile-10.56@124, Late 80's Firebird, LT1, mild ported heads, Hyd Bullet roller 230@.050, 3200Lbs, 750 holley
Not sure if it's a stock shortblock, but usually it will say otherwise
14. Mike Comp T/A-#57-10.89@128, stock LT1 bottom end/cam, LT4 heads, 3000 stall, 3800lbs
20. BOLO-94Z28, 11.04@122.18,Stock shortblock,H/C/I,4L60E,4000 stall,4.10 Stock 10 bolt
Plus i'm sure there are guys out there who don't even login on here, but maybe do elsewhere. I would just like to know what the record is that any of you guys know of. Preferably in a 4th gen car.
https://ls1tech.com/forums/lt1-lt4-m...na-9s-n2o.html
10.55 @ 127.50 on motor, 9.86 @ 139.3 on the bottle. Those silly AI guys...
I am positive that I can get my car into the 10's as it sits with some nice fall air, because we can get negative DA around here in Oct and Nov. I will certainly need a cylinder head swap to get me into the 10's solidly in the heat. Well....now I know the number I have to hit to be #1, lol. Not sure if I can get there but i'm gonna try. Looking at his timeslip, I have to question how the hell he can cut a 1.41 60ft with a mild/tight converter. Some guys don't like to give up theri secrets though, and they don't like to tell all the details either, lol. I'm cool with that!
I know Butch (BOLO) car has a ten second pass he only made it to the track one time as far as I know with the new cam he's running. The mph he's running is good for atleast a 10.90.
