MGW shifter rattle fix?
Old 07-25-2010, 07:54 AM
Martin HD-28's Avatar
Default MGW shifter rattle fix?
I had a B&M Ripper that rattled pretty bad so since I wanted a shorter shifter, I bought an MGW to replace it. Needless to say, it rattles pretty bad also. I know it's just where the ball jumps around in the cup so does anyone have ideas on how to get rid of the rattle? I think maybe I could wrap the ball in rubber heat tape to keep the noise down? Whatcha think?
Old 07-25-2010, 09:30 AM
HavATampa's Avatar
Have you considered replacing the cup? You can go back with another plastic one or upgrade it to a bronze one. Wrapping it in tape isn't a good idea. It might be a quick and easy short term fix, but the tape will wear down and come apart over time and get in your transmission.
Old 07-25-2010, 01:48 PM
SladeX's Avatar
The bronze one doesn't help rattle, a new plastic one would be best to quiet it up.
Old 07-25-2010, 03:51 PM
I took the tightening nut off of my shifter ball and the rattle is gone!!!!
Quick Reply: MGW shifter rattle fix?
