Any Ideas??
Any Ideas??
my a/c is not blowing very much, but it is still blowing cold, and when I open the hood, it is all frosty and the lines are real sweaty....anyone know why this is happeneing??
Probably low of freon. Get you a set of gauges from Harbor Freight http://www.harborfreight.com/a-c-man...set-92649.html
and check the pressures.
Whenever a system freezes up ( home or auto ) it is usually one of two things low freon or more often air flow. Check your evap coil its probably either has no filter and is clogged or the filter is clogged and cant pull enough air through it. j
