? wiring vss to abs sensor
im wiring my vss from my m6 to the abs sensor, i removed the pigtail a long time ago so dont know what color the two outputs would be.
looking at the drivers wheel. which is high and which is low on the sensor itself (top pin/bottom pin).
and which of the vss wires ppl/ or yellow goes to which one.
thanks
thanks
It dont matter, just hook it up and it works. You will then just have to rescale the speedo till its correct. Usually i just do a percentage fix on this route. Like if it is 50on the dash and you are actually going 75 then i just 50/75=.71 so i add 29 percent to the H0101 value
