need help cant figure this one out, please help!!
this problem has been plaguing me for a while now. the motor runs great without a flaw until i get to operating temp then it bogs down and will die even sitting in place. if i give it gas while its bogging down it will backfire and die (almost sounds like a misfire) when i turn the switch off after it dies and restart it, it runs good for 10-15 minutes then the same thing happens again. i have recently replaced the battery, alt, fuel pump, water pump and thermostat and none of this has helped. im also not sure if i can have a diagnostic test ran being that the ls1 is in a third gen camaro, bought it that way and the wiring seems a little screwy. i have drove this car for over two years without a problem this just recently started happening and i have no idea how to fix it. any suggestion would be greatly appreciated.
well i cant tell if it is throwing codes because im not sure how to check it being that the engine is in a 88 camaro.... with that said are the O2 sensors something i can clean to check or is it something that i would have to replace?
thanks
thanks
