Shock issue
Old 07-28-2010, 12:07 AM
frankenbitch's Avatar
Default Shock issue
The top of my bilstein shock where the threads are is rubbing on the inner side of my front right fender causeing an awful squeeking noise. I pulled the coilover out and saw fresh metal up top on the inside and the threaded portion being worn down a bit on the very end of the shock. The bolt is in rock solid and the isolater underneath is new. what would cause this? i had 1LE bushings put in recently, and all the ball joints on that side are new...Even the top strut mount is new. WTF??
Old 07-28-2010, 01:01 PM
Weezzer's Avatar
Either post some pictures for an educated solution or let 1000 people guess at the answer.
Which one would you rather do?
Old 07-28-2010, 01:03 PM
I will take it apart tommorow (thurs)
