New build....small issues
Old 07-30-2010, 11:49 PM
offroadfury6's Avatar
Default New build....small issues
before I had all my drivetrain work done, I was having issues getting the car into gears, clutch pedal was dying so....
I had tick perf. do a lvl 2 rebuild on my t-56, put in a monster lvl 3 clutch/PP/and flywheel, replaced with new slave, T/O bearing and pilot bearing...set-up has about 500 miles on it now...today I noticed when I go into 2nd and 3rd that I can hear a very light quick grind sometimes. also for the first time today when the car was in "N" I heard some kind of a chatter or rattle while idleing, pushed the clutch in, went away...almost same sound when someone's throwout bearing goes bad...
now with all this new stuff, I shouldn't have any issues...only thing we didn't replace was the stock master cyl. ( I have a tick one ). didn't install cause looks like a hard job
anyone know why my T-56 could be acting alil crazy? is it the master cyl? should I bleed it again? I know my hydraulic fluid is pure black when you take the cap off, defently old stuff there...
thanks
Old 07-30-2010, 11:53 PM
fleetmgr's Avatar
thanks
I think you just answered your own question.
