Windage tray bolts
Old 07-31-2010, 10:47 AM
mjollnir's Avatar
Default Windage tray bolts
Here is the bottom of my block
I have to install the windage tray but I'm not sure which bolts or studs I should order
Engine is LQ4 2001, oil pan is C5, windage tray is GMPP 12558253
Old 07-31-2010, 11:23 AM
Mkos1980's Avatar
When I took off the oil pan on my LQ4 I reused the nuts from the LQ4 tray for my F body setup. Studs are the same.
Old 07-31-2010, 11:43 AM
mjollnir's Avatar
Does it mean I can reuse the 10 bolts (end of the studs) we can see on my picture?
Old 07-31-2010, 11:52 AM
KRAZY K 2000 TA's Avatar
yes just make sure there is clearance mine had to be spaced away from the crank on my 402
Old 07-31-2010, 11:57 AM
mjollnir's Avatar
Cool, thank you guys
Quick Reply: Windage tray bolts
