383 Stroker question
Ok this is not an update for my build, it is a question for general readers and for my own knowledge. Please make your explanations understandable for newbies. The question is what is the difference between a LT1 383 stroker and a regular 350 LT1? Also what is the difference in horsepower on average. I am asking because someone said that they are the same thing and there is not too much of a difference, and although I am new to this, I don't agree with that. Someone please explain this.
One more question. What is the average price for a machine shop to bore the engine and port the engine?
Thanks
Thanks
Thanks
Thanks
383 is a 4.030" bore with a 3.75" stroke.
396 is a 4.030" bore with a 3.85" stroke.
The horsepower difference lies in the valvetrain for the most part and has little to do with the rotating assembly. However, a stroker motor will almost always have more lower end torque due to the longer stroke.
Stroker motors have larger cylinders. Subsequently they can support more aggressive camshaft profiles (those with longer durations) and cylinder heads to fill up the extra volume.
Prices vary as there are many many extra costs that are incurred during the machining process that doesn't span every person's build requirements.
This is only the tip of the iceberg - I'm sure others will chime in.
