Will any GM 4 wire o2 sensor work with LQ9 pcm?
I have a set of 4 wire o2 sensors from a C6 vette with square plug (front o2's), problem is my harness is from a '05 Escalade LQ9 and it has a different style 4 wire plug. I figure I can swap harnesses and run the 4 wire but I just want to make sure there was no difference.
When I look it up on Autozone.com the generic o2 sensor part numbers appear to be the same.
Any insight?
Any insight?
