Dropping Transmission
no it aint too bad. just put it up on jack stands or a lift if you are lucky, drain the oil, pull the torque arm , take the console out and remove shifter, unplug everything, put your jack underneath it and take out crossmember and bellhousing bolts. and slowly drop her down.
CARTEK Racing
Ive taken mine out alone... and with a Pro 5.0 shifter I can unbolt the shifter from under the car with a 10mm ratcheting wrentch, no need to open up the console.
laytoncamaro forgot that you need to remove the driveshaft as well lol.
