Jumps to security mode for no reason
Old 08-06-2010, 12:32 PM
02*C5's Avatar
Default Jumps to security mode for no reason
So I have had this happen and I am to my whits end. Lately my car will jump on security mode no matter what. I was stopped at a drive through she turned off and couldn't start her for about 10 min. I was at a stop light same dam thing she just decided to turn off and would not start again for 10 min. Had her diagnosed no codes. I don't have the fob bought the car 4 years ago with out it is there a bypass to the security mode can any one help. This started 3-4 weeks ago.
Thanks
its a 2002 C5
Old 08-06-2010, 01:46 PM
Randy WS6's Avatar
Check the two white wire going in you key switch (Passive Key-II) The wire tend to brake apart and will cause the car not to start and give a security light but no code. I have had the same problem before. Try this, if you are out and the car wont start. Turn the key to the start position and hold it and use the tilt wheel to tilt the wheel back and forth as you have the key held in the start position this will work the wires ,and can cause the wires to touch and start the car, It has work for me. Just trying to help.
Old 08-06-2010, 09:03 PM
02*C5's Avatar
thanks ill check it out
