carbed blow through!!!!!!
Old 08-07-2010, 01:50 AM
goodolboy32's Avatar
Default carbed blow through!!!!!!
hey everyone, begining the process of doin an ls swap into a g-body and have long decided to go carbed! now i saw the post about the ls in a g-body and i'm sure fitment as far as motor will be fine! just got done building a turbo kit, in a mustang, with a friend and am all for turbo now! i've been having trouble finding pics of anyone with turbo blow throgh ls motors, or just blow through ls in general? usually because the motor is naturally efi, guys don't steer away from it especially when it come to tunning. i'm still very used to blow through carbs now and would be more comfortable with that! if anyone knows of any pics or links it would be greatly appreciated. Thanks!
-Frank
Old 08-07-2010, 10:18 AM
3pedals's Avatar
I dont have any pics to help you out, but I'd love to see pics of your setup as you build it, keep us posted.
Old 08-07-2010, 10:38 AM
thedrill's Avatar
Default blow thru carb
The only turbo car I have owned with a blow through carb was back home in the UK, the Rover Maestro Turbo, a quick car with so much torque steer that you could feel the floor twist with your feet whilst accellerating hard, lol.
http://freespace.virgin.net/martin.w...bo1/turbo1.htm
Here are some pictures.
Old 08-08-2010, 03:52 AM
thanks for the help it all helps!!!
Old 08-08-2010, 10:24 AM
danbap's Avatar
i need to get some new/better pics but here is the only one i have right now.
Old 08-09-2010, 08:38 PM
nice set up thanks for the pic, it's honestlt the first one i've evon ceen blow through. thanks!
-Frank
Old 08-09-2010, 09:01 PM
3pedals's Avatar
if your used to tuning blow through carb setups, the LS will be NO different, so dont be afraid, just "get er done"
Looks good in the pic, let us know how it runs
Old 08-12-2010, 09:56 PM
as far as ignition goes i'm planning on going with the stock coils and the 6ls box. juct curious to know if the tunning with that box is done with a laptop. we just got done building a turbo blow throgh 306 mustang with a programmable digital 7. i'm guessing it's like a cut down version of that for the 6ls? as far as the software goes? thanks for the help!
-Frank
Old 08-12-2010, 10:33 PM
danbap's Avatar
ive never messed with the 7 so i cant tell you anything about that. the biggest thing is that the 6ls is not set up to run boost. you can do it just fine but you have to do some math in your head as you go.
Old 08-12-2010, 10:59 PM
ok well any other suggestions! tried to look on msd's wedsite but the 6ls is all they got. ya know! only other route was ditributor with a better bow but obviously much more cash to do! i'm guessing the 6ls would get confused when boost pressure is seen it the map sensor rather than vaccuum?
Old 08-12-2010, 11:07 PM
danbap's Avatar
it works fine. you set a base timing at say 10* is the least amount of timing you want to have at full boost say 10psi. but you want to run 30* not in boost so you have vacuum advance add in 20* of timing any time your in vacuum. on top of the 10* base. once you go into boost you can have it pull out as much or as little timing as you want. but with it set up like that you can only pull timing down to 10*. let me know if that makes sense or not im tired and im going to bed.
Old 08-12-2010, 11:11 PM
lol it's all good man i got it! just wasn't sure exactly what the box was capable of, that helps a lot!!! sorry to keep ya up! thanks again!
-Frank
Old 08-13-2010, 07:35 AM
StatoJase's Avatar
I run a vortech t trim supercharged blow thru ls1 with the msd 6010 box. I have the pro data software on my laptop and only use the map table with a 2 bar map sensor to control the timing. the rpm table is zero'd out. Works well for me.
Old 08-13-2010, 05:01 PM
danbap's Avatar
im not really sure why i did end up using the rpm table but it works so ill leave it be. ha
Old 08-13-2010, 07:25 PM
StatoJase's Avatar
here is a couple pics of mine. In the process of doing panel and paint. Slapped it back together to get some dyno time.
Attached Thumbnails carbed blow through!!!!!!-p100076e.jpg   carbed blow through!!!!!!-p1000771.jpg
Old 08-17-2010, 12:15 AM
Default good deal
looks good man thanks can't wait to toy with the software. thanks for the pics!
-Frank
Old 05-27-2014, 08:55 PM
D.white's Avatar
Default supercharged blow thru set up...HELP!!!
Hello...im doing an 6.0 LQ4 ls swap. .but im doing an votech V3 supercharger blow thru....i have an single plane edelbrock intake with supercharger cam,new lifters, ported ls6 oil pump, pushrods, springs, msd box that came with intake...my kit pushes out 7 to 9lbs of boost and have a quick fuel 750 blow thru Carb/ my set up looks exactly like yours on the pic..,,where do set my timing at and do i need a 2 bar map sensor...how many lbs of to set fuel pressure and regulator,what kind of spark plugs and gap size this my first time doing this and don't wanna mess up anything. .could you please help me/ explain on full detail..you can call me if you like ...my name is D..901 644 2447 call or text anytime ....thanks
Old 05-27-2014, 09:06 PM
D.white's Avatar
..hello...where did you set your timing at....i have a carburated supercharger set up on my lq4....it pushing out 7 to 9lbs...do i have to use a 2 bar map....please help....you can call me if you like to explain it....my name is D 901 644 2447 call or text anytime please. ..this'd my first swap and wanna get it right ...thanks
Quick Reply: carbed blow through!!!!!!
