98-02 Camaro interior parts needed. visor, small door panel
I would like:
-Driver-side visor
-Passenger-side, panel behind the door handle that is screwed in. I also need the screw that goes from the ground, up into the actual handle on the door. It's hard to see, you have to bend over and look up into the handle I believe.. I can draw a pic if needed.
-Driver-side visor
