160 thermostat question/discussion
alright so i was at work the other day and i was talking to some of the guys about cars and i mentioned i was considering switching to a 160 t-stat. I got a reply from a guy the it would create condensation and water contamination in the oil and then lead to oil slugging. i called bs and it turned into a pretty lengthy discussion. i could be wrong i have never heard or seen it.
me and my father ran a small buisness for a while with several trucks. the only time i have seen engine slugging was in the tbi 350 trucks we had more specifically the two 92 gmcs and i figured it was from the trucks working so hard. as i understood it engine slugging only came from extreme heat breaking down the oil. i know that when water and oil mix you can kinda get a white puss like substance but thats not what we are talking about.
so what do you think? do you guys say bs?
I had my doubts about a 160 thermo until i tried it. Even with it my engine still sits at 170 on a real cool night and 180s on hot days.
160 is just were is starts to open, not where it sits.
edit: this is on a ls1, didnt read the section but shouldnt be much different.
Peopl;e who think bad things about a 160 stat in a LT1 are applying old school knowledge to a newer cooling system design.
A 160 stat in a early 90s TBI motor would not even allow it to get into closed loop operation and DID cause problems. Ask your friend what the stock stat was and I bet he SWEARS it had to be a 195.
Because of the reverse flow cooling a 180 stat in a LT1 results in similar cylinder temps as a 195 in a gen 1, so running a 160 in a LT1 is nowhere near as drastic as a 160 in a gen 1, the cylinder calls and bottom of the block still stay nice and warm but you keep the heads cool.
All that said I am not convinced the 160stat is the wonderful mod it is claimed to be on the forums. The more I learn the less faith I put in "conventional wisdom" and popular parts or vendors.
Here I what I alway do, 160 for summer, and 180 for winter. But im thinking running 160 year round, if you drive your car hard and long, you wont have problem with those thing you worried about.
Id like to get into this topic a bit, but i think itd be thread jacking Anyways my 95 Trans Am seems to get real hot, its around 80-90 degrees here in PA right now, and in stop and go, it gets almost to the line in between 210 and 260, then when i get it running and air flowing it gets to 210 but shouldnt it still be lower? I plan on geting the computer tuned and get a 160 just to be safe.
the late year lt1s have a better fan set up. in 1993 and 94 they had one high speed fan and one low speed fan. in 1995 and up they changed it so both fans ran and were both able to do low and high speed. i read that on shbox.com
im curious to know if it could create engine slugging.
