pcm pin for map sensor
Old 08-07-2010, 10:39 PM
2002RamAir's Avatar
Default pcm pin for map sensor
What pin on the pcm is the map sensor? I've got some wiring to do for my Meth setup and would prefer to tap into the map at the pcm then pull the intake off again.
Thanks
Old 08-07-2010, 10:44 PM
MUSTANGBRKR02's Avatar
http://ls1tuningguide.com/tuninghelpfiles.php
There is a link to wiring schematics here.
Old 08-08-2010, 06:11 AM
khaotic's Avatar
Thanks
On your pcm red connector its pin 32 lightgreen wire for Map sensor
