LQ4 in a 83 camaro
Old 08-08-2010, 10:22 AM
onebad400's Avatar
Default LQ4 in a 83 camaro
I am building a 6.0 iron block for my 83 camaro. I need some help with the build. I am planning on using a stock low mileage bottom end with a set of L92 heads and a carb intake. Where I need some help is in the cam, what cam for the engine keep in mind this is going to be a pump gas car, and needs to be drivable, with vacume accessories. I also was wondering if anyone knew what kind of compression I would be running? The tunning and computer part in all honest are scaring me pretty bad, ao any help with this part would be helpful
Old 08-08-2010, 10:34 AM
deuce4935's Avatar
I recommend the GMPP ASA cam pt#12480110, the specs are 226/236, .525" i/e on a 110.
Old 08-08-2010, 12:23 PM
onebad400's Avatar
is that with stock ls rockers? also does it like power adders like a turbo?
Old 08-08-2010, 12:53 PM
deuce4935's Avatar
Yeah thats with stock rockers, as for a turbo that should be okay or may want to go with a 112 0r 114 cl.
