Mid 10 sec '04 Goat
Old 08-09-2010, 11:29 AM
V3NOM GTO's Avatar
Default Mid 10 sec '04 Goat
Has 90K on it. Its an M6, red on red but the seats are black. Has rear seats out of it.
Last year it went 10.47 @ 135 with 1.61 60' on Hoosier Drag radials. I think it could see 9's with suspension and a true slick. This is everything I can think of good and bad.
Pros
Vic Jr intake with Direct Port
Stand alone for N20
Torquer V.3 Cam
Z06 243's ported and polished
Spec Stage 3 clutch
GMM Race shifter
Custom Built CAI (reads ambiant intake temps)
Greg Weld dragstars (can't get these anymore)
Banshee hood (cut to fit intake)
Custom built 3" exhaust with Dynomax race bullets (sounds nasty)
Bumper has dual twin 3.5" tips (cut on pass side, looks good)
Whyskey Tango Front splitter, painted to match car (can't get these anymore)
Alminum drive shaft spacers (custom made)
Optima Red Top
Comes with Nitrous switch panel, bottle mount, NOS bottle
Drag bags
Walbaro 255 in tank
3750lb race weight
Cons
No A/C or heat (have all the stuff to put back on)
Starter going bad
Small drain on Batt (pretty sure it's from the starter)
Tranny needs built (still shifts fine 2-3 syncro is going out)
Needs new tires in back (fronts are good)
Needs driveshaft (dent)
small dent in driver fender
N20 needs to be wired (pulled it out looking for batt drain)
Rad has small leak
Old 08-10-2010, 09:56 AM
V3NOM GTO's Avatar
Had a guy offer 12,500. Is it fair deal??? Need help on this ASAP!
