Engine vacuum question
Hey guys I have a cc503 cam on my new rebuilt motor and after testing the vacuum at each port I was getting 16-17 inHg at idle. Does this seem too low for the cam that I have??
Im trying to track down a lean condition that is only at idle, according to Datamaster its 132-139 BLM at idle. I checked for vacuum leaks by spraying carb cleaner on each line and didnt find anything. There is no exhaust leaks and I changed another set of injectors with no luck. Any help would be great
Seems right to me just as long as the readings are steady with no sudden bid dips and recovery.
132 isn't all that bad either unless you're really **** about getting 128. If you are, good luck. If it was me, I wouldn't be concerned.
Jake
Jake
