manual fan switches?
Old 08-11-2010, 03:29 PM
SS4Luck's Avatar
Default manual fan switches?
I read a write up once that used leds and a 3 way switch and blah blah blah and i was wondering if there was a way i could use 2 seperate switches for high and low and if there was a way to get LEDS for them so that i can tell when they are on or not.
i dont really do create your own wiring solutions very well, but i understand how wiring is supposed to be and can fallow directions pretty well. I wanted to run two switches in an HVAC panel i made next to a few other switches i have.. They all have LEDS so ya... Anyone?
Old 08-11-2010, 03:48 PM
2001NBMZ28's Avatar
I have the SLP fan switch and wired leds to it, works even with the switch in the middle position (PCM commanded) and illuminates one on low, both on high using two separate leds. Not sure if that's what you're looking for.
Old 08-11-2010, 11:51 PM
SS4Luck's Avatar
i really dont wanna spend the $70 for the slp one when i can make one myself
Old 08-11-2010, 11:56 PM
garyyz's Avatar
i would make my own if you can do a nice job go for it
Old 08-12-2010, 04:44 PM
SS4Luck's Avatar
im tackling this tomorrow. Ill post pictures when done
Old 08-12-2010, 04:46 PM
AznMuscle's Avatar
Good luck man. Keep us updated tomorrow.
Old 08-14-2010, 08:13 PM
TORCHD 02 TA's Avatar
I used that write up.. Here are my pics
LOW
HI
