1969 chevelle LS1
1969 chevelle LS1
R these mounts too high$$?...if so which ones should i go with that r good and also which oil pan....thanks miguel
http://www.brphotrods.com/mm5/mercha...gory_Code=CNV4
Nah that's not bad plus it'll bolt in and you don't have to reengineer the wheel to put it in. I believe that most of BRPs kits are designed around the LH8/muscle car swap pan.
