5th gear kinda slipping
Old 08-12-2010, 02:49 AM
AUburn1's Avatar
Default 5th gear kinda slipping
got a t56 thats going into an s10 truck with a 5.3. 5th gear is slipping when i spin the input shaft with much force. also is making a sound like the gears are just skimming across one another. all other gears are solid. opened the case up for just a visual inspection and all the gears look to be in really good shape. was told tranny had 60k on it. any input would be appreciated.
Old 08-12-2010, 07:35 AM
85MikeTPI's Avatar
Does 6th gear work fine, or is it like 6th?
IF only 5th, it sounds like it's not fully engaging the gear, which would be a fork pad or synchro key problem. Once engaged, the gears are locked and there's no chance of "slipping".
Old 08-12-2010, 03:06 PM
AUburn1's Avatar
yea 6th works fine its just 5th. debating on fixing it myself or takin it to ashop.
