O2B1S1 stuck in 0.44 - 0.46 range
Hey all. I just installed headers and a re-tuned PCM and logged some data on Autotap. It shows the O2B1S1 stuck in an unwavering range of 0.44 - 0.46v. This is at all TPAs, including WOT, and all rpms from 1000 - 5800.
I think a leak can cause a sensor to read low, but can't believe it would stay constant under a wide variety of conditions.
Any thoughts to the cause? Loose electrical connection (haven't checked yet), bad sensor?
Thanks
BobP
Thanks
BobP
1 Post
That is how they read when they are disconnected - check the connector first... If it is connected (to the right connector - have seen some mistakenly connect to the rear connectors), then you have a bad pin or wire burnt or something...
I love my hobby.
BobP
