Fix my rear pinion seal leak, help me remove all the grease and oil
Old 08-18-2010, 05:45 PM
killagt's Avatar
Default Fix my rear pinion seal leak, help me remove all the grease and oil
My pinion seal was leak for some time now, and my rear diff is full of grease, some on the exhault, some on the firewall top of the drive shalf, what is best way to remove all the grease and oil that stuck their, thanks ?
1: if I spray some engine degreaser and spray it down with water on the rear diff , will water get into my rear diff ?
2: will brake cleaner damage or eat up rear diff cover gasket ? or pinion seal gasket ?
3: will brake engine degreaser damage or eat up rear diff cover gasket ? or pinion seal gasket ?
Old 08-18-2010, 06:15 PM
BlackBird87's Avatar
Just spray it with degreaser i like simple green let it sit for a while and wipe it down and repeat, you could spray it with a hose but youre just gonna end up with a mess
Old 08-18-2010, 06:24 PM
killagt's Avatar
thanks for the tips, will simple green will not damage any kind of gasket and seal right ?
Old 08-18-2010, 06:26 PM
It shouldnt simple green is pretty safe to work with
Old 08-18-2010, 07:17 PM
killagt's Avatar
thank you, i will give it a try
Old 08-18-2010, 07:47 PM
Big bird55's Avatar
yep i use simple green on my stuff. or a industrial form of it my dad gets from work
