UMI Performance
08-19-2010, 01:01 PM
2010-2011 Camaro Rear Trailing Arms
Starting at: $119.99
Application:
2010-2011 Chevrolet Camaro (All Models)
2008-2009 Pontiac G8 (All Models)
Minimize wheel hop and increase rear end stability on your fifth generation Camaro with a set of UMI Performance trailing arms. These heavy duty trailing arms replace the factory stamped arms reducing flex and bushing deflection resulting in a more controllable vehicle. UMI’s trailing arms are fabricated from 1” x 2” rectangular tubing and feature ¼” thick CNC machined mounting plates. They are assembled with fluted, greaseable and low deflection polyurethane bushings from Energy Suspension. Trailing arms are a direct bolt in and installation time is less than an hour using basic hand tools.
http://www.umiperformance.com/catalog/images/large/2515a_LRG.jpg
Application:
