Truck Alternator Wiring (Yes, I've searched!)
Old 08-19-2010, 01:29 PM
dville_gt's Avatar
Default Truck Alternator Wiring (Yes, I've searched!)
Can't seem to find a definitive answer. I am using an alternator off of a '05 Cadillac Escalade (LQ9).
There is the power wire (thick gauge, goes to the battery positive).
There is a brown wire that runs to the PCM
Then there was a wire that ran to some type of box that attaches to the negative battery cable. I am not running this box so now I just have a short wire coming out of the pigtail that I have no idea where to run it to. I talked to a GM guy who said the box that this wire ran to was some type of phase controller for the alternator (I have no idea why a car would need this).
Can anyone please help, fat red to battery, brown to pcm, other wire to???
Old 08-19-2010, 08:35 PM
FastKat's Avatar
That is the Generator Battery Control Module. It helps the PCM control the alternator. You can read all about it here:
(It is a PDF file)
http://www.google.com/url?sa=t&sourc...0HupErMqb1OYLw
Or, if you want the HTML version, you can click on this link (which is a google search) and then click on the very first search result that comes up.
http://www.google.com/search?hl=en&c...=&oq=&gs_rfai=
Good luck with this one!
-Dave
Quick Reply: Truck Alternator Wiring (Yes, I've searched!)
