new opti issue?
new opti issue?
i just put a new opti and water pump in a friends 97z. i`ve done a ton of opti`s his was bogging and miss firing under trottle sitting still and mostly on the road. i`ve seen it a hundred times. so i put a new opti and water pump, still doing it.? sitting still it idles fine. recently he had a fuel pump put in and the car has 97000+ miles with only plugs put in. it is throughing codes i just need to get a scanner on it. anybody got any ideas.
Spark arcing to ground usually at one of the spark plug wire boots.
Plug wire(s) routed too close to the ICM
Exhaust leak usually upstream of the 02, but not too far downstream can do it too.
I'm assuming nothing's been done under the valve covers before this started.
Jake
Jake
