three bolt or single?
Old 08-23-2010, 01:20 AM
cfgioja's Avatar
Default three bolt or single?
I found a short block and it needs a cam still and probably the cam gear. While looking through cams, it asked if I had a single bolt or three bolt.
the block is an ls1 block with forged pistons and h beam rods and a stock crank.
I also am running ls6 heads with dual valve springs.
Any help would be great.
Thanks
Old 08-23-2010, 02:22 AM
Trunion King
bene's Avatar
numero tres
Old 08-23-2010, 05:48 AM
69LT1Bird's Avatar
You have a 3 bolt cam, the newer engines went to the single bolt.
Old 08-23-2010, 09:28 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
^^Bingo! GM started putting single bolt cams in engines around 2008.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 08-23-2010, 12:47 PM
cfgioja's Avatar
cool. thanks for the help
