another nitrous question?
is anyone running 110 octane fuel and spraying a 100 shot with out pulling timming? can it be done? sorry for the questions, just new to nitrous.
Ive sprayed a 125 shot with a stock tune on 93 pleny of times in my Formula and never had a problem just make sure you put in a set of BR6EF NGK plugs for the nitrous and you will be fine.
Guest
Posts: n/a
FYI...I would NEVER run nitrous without retarding timing.
The combustion process is drastically sped up when using nitrous this is why you want to retard timing. Raising the octane will help prevent detonation but it does not get the burn started at the correct time.
Now with that said are there people out there that do it, yes, but there are also people that play russian roulette. Your decision.
