speedtweakerz 255 install
so i bought the speedtweakerz walbro 255lph fuel pump kit.. my question is.. do i need to use the stock fuelbucket? or can i just use a pipe clamp and atach the fuel pump to the stock bracket?
Use the stock bucket. The bucket serves to always keep the pump submerged in fuel. This helps keeps the pump cool and also prevents it's exposure to air, which when used long enough can promote corrosion on the internals of the fuel pump, resulting in failure. It also prevents any fuel aeration if you do any hard cornering when low on fuel.
