Wheel Spacers - Bolt Thru vs. Bolt On
I am going to need some wheel spacers to fit my new calipers on the front of my car. I think I can get by with 15mm spacers but I am torn on what type to get.
If I get the 15mm one it would be a hub centric bolt thru design. I would push out my stock studs and put on ones that I would assume are 15mm longer and the spacer would get sandwiched between the rotor and the wheel.
If I go with a 20mm spacer it would get bolted to the rotor (not sure if it uses the stock studs or if I would have to put shorter ones in?) and the wheel would get bolted to the spacer.
I originally thought the 20mm spacer was the most reliable sounding idea but I'm having second thoughts, especially if it wants me to keep my stock studs that are almost 9 years old.
Also, if I do get the 15mm from Eibach are the studs included any good or should I be getting some from ARP or something?
Thanks
Thanks
Thanks for the feedback guys. I found a company that makes bolt-on adapters which are hub-centric from the adapter to the hub and from the adapter to the wheel. Any thoughts on that opposed to just a single spacing plate with longer studs?
