Blowthrough 6.0 FOX
Blowthrough 6.0 FOX
Hello everyone. Im kinda new to this site but its awesome. Just a few questions. Has anyone run the MSD 6010 under boost? does it work good? Planning on running a quickfuel with either twin 70's or a BW S400. Prob go with trick flow heads. Shooting for high 9's with blowthrough carb setup. Thanks for the help.
My mustang used to have a blowthrough carb/set-up. Had a bone stock 5.0 with a MasterPower t-70. I modified a Holley 600 myself for blowthrough. It ran great until I decided to part it out.
DAMN! i wanted to be the only blow thru 6.0l in a fox!!! i use the msd6010 no problem once you figure it out its easy. its not set up to pull timing during boost but you can do it. and also its in psia which takes a little bit to get use to. but other then that it works fine.
