Cam Suggestion?
Cam Suggestion?
Im fixing to start my cam install, but first I need a good cam, and heads, I will be racing on the street and on the strip. any suggestions?
228/232 .610/.610 113 cam or similar custom spec'd grind (check PTV first)
AFR 210cc heads
PAC .650 lift springs for less weight
stock rockers with trunion upgrade
hardened pushrods
LS2 timing chain
LS6 oil pump
GM MLS head gaskets, don't use cometics
Will still have great street manors with a good tune, mpg shouldn't suffer too much with the high velocity heads.
AFR 210cc heads
hardened pushrods
LS2 timing chain
LS6 oil pump
I dunno, itll take me a little while, but I wanted to go ahead and get everything, because right now im laying low and I was gonna cam swap, and put some other goodies on there, so it will be a different beast
