WTB Differential Spacers/Shims
Hi I know some of you here work a lot on rear end rebuilds and such, and some shims must be left over from assembly. Instead of collecting dust sell em to me. I need a differential spacer+shims to achieve the following :
target value for is 0.2485(left) and 0.2340(right) total .4825
Need to finish car this weekend.
If you live around NYC, North/Central NJ I would pick em up.
In case you wonder why I need them visit here:
https://ls1tech.com/forums/gears-axl...ngs-check.html
I still am unable to locate correct shims. If anyone has them please response, and I guess finishing the car this weekend is out of the question :-(
shims needed:
or
target value for is 0.2495(left) and 0.2330(right) total .4825
shims needed:
or
ski23
That is just my luck.
I just found out that only from factory the rear axles come with one piece shim. apparently during rebuild I need shim + spacer.
It is 95% possibility I am going to have to go to stealer tomorrow, as my last effort does any one have any of the following combination?
or
or
at least .2340 or .2330 shim + .006 or .007 shim respectively.
Thanks for all your responses.
or
or
I have a **** ton of these things, I really dont feel like measuring tomorrow but if you would be willing to wait I might could help you out. When preloading the carrier bearings, dont get obsessive, just get it slightly snug for used bearings and pretty snug for new bearings. I even, when I open up old 10 bolts, add a really thin shim on both sides to take up the slack of worn bearings. **** works like a charm.
